1983 280zx problem running, fuel?
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
Antiman
Car: 1983 280zx Turbo
i recently put a new heater core in my car and every since it has had problems running. its like it is flooding itself trying to start and when it does start it runs fine until i change gears or stop itslike any time i let off the gas it has a problem getting back its pressure.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
ok, did you maybe knock the connector off the CHTS? it's on the head on the passanger side just forward of where the heater hoses go through the firewall, if you unplugged it or even knocked it loose it causes all kinds of fuel to dump in
Antiman
could have but that would cause it to do it all of the time correct?
evildky
06 Nissan 350Z GT
only when warm, it's pretty easy to check just takes ten seconds to pull the 2 pin connector off and push it back on securely, remember the cold engine needs the extra fuel, once warmed up it cuts back on fuel, if the CHTS is bad or disconnected it thinks the egnine is cold all the time and it will keep dumping fuel
straitsix
Car: 1981 280zx gl
--careful, that's where the most evil, brittle coolant hose of all lives... And replacing it it only worse than having it leak...
evildky
06 Nissan 350Z GT
hose is cheap, replace all of them and worry n omore, I had one of the old hard lines rupture at gainseville drag stip years ago, and when I got home I got new hoses
Return to “Datsun Z Forum”
