1982 720 nissan king kab rough idle after complete tune up
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
sandydog
Car: nissan truck
what else can i check ?to solve fluctuation of idle..idle prevents truck from passing smog test.
replaced all 8 plugs and gapped correctly,new plug wires pcv airfilterfuel filter fresh gasnew canister filter
smog tech connects truck to machine, and idle varies, preventing machine from beginning test.through tach sensor wire.
vacumm lines all are in place nothing on truck is altered from stockauto transmission-
trucks runs great
idle needs resolved.
sandydog
Car: nissan truck
btt
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
Not sure how much it will help but you could run seafoam in your gas see if it cleans it up, or carb cleaner.
Other than that your EGR valve maybe not opening properly or getting stuck open.
Might have a look at your valvetrain.
so many things can affect idle that its pretty much just running through the emissions or replacing vacuum lines. It seems the napz motors rely heavily on their vacuums. They were designed as an emissions truck so their finicky to say the least. I'm glad they don't smog here yet.
breadbox
89 Koop
84 720 4x4KC
Also varies how much? like 100rpm or like a slight lope like 330rpm.
Return to “Datsun 720”
