evildky »
https://forums.nicoclub.com/evildky-u13100.html
Thu Apr 24, 2008 10:12 am
the compression isn't enough of a problem to cause any real running problems, and I'd highly recomend against any seafoam or other snake oils till you actually know the source fo the problem, just randomly throwing solutions at an ynknown problem seldom helps
and nope no coses it's not OBD, it's bosch L jetronic, which sucks
we know you are getting compression, how about spark and fuel? fuel pump coming on? injector relay clicking? injectors clicking? spark at the distributor? spark at the plug? everything hooked up? no broken dangling or damaged wires?
