1982 280zx need to remove handbarake cable from caliper
A home for 1983–1989 300ZX owners!
boldersgirl
I need to know how to remove the handbrake cable from the back side of the caliper. Thanks for the other help.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
with the tensoin reliaved form the cable pull the retainer clip at the cable stay that sticks out the back of the calliper, then back the cable out and the cable itself will fit through the slot on the bracket, then just swing the cable around and push the block at the end of the cable up out of the grove, it's pretty self explanitory when you look at it
boldersgirl
I have a caliper w/brake cable attached, cable cut at equilizer. I have removed retaining clip and can't get the cable through the slot. Is the retaining clip just a metal shim?
evildky
06 Nissan 350Z GT
you have to pull the cable housing back so that the cable itself can slide sideways out of the slot, if the cable is siezed and useless just cut it between the bracket and the pivot
Return to “300ZX (Z31) Forum”
