1982 280ZX 2+2: Engine idle issue
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
Brianppp
I just received this car from a friend and so far everything runs great. It has a minor idling issue though. The car will idle around 800rpm's, but once I rev it up and stop it will bog down to 500rpm's for a few seconds then go back up to 800. I'm suspecting a vacuum leak somewhere, all the vacuum hoses are original so there are probably a few leaks here and there. I've replaced the battery, cap, rotor, spark plugs, plug wires, and air filter so far. I was told this was a common Nissan problem. Any suggestions fellow Z owners?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
lots of little valves on the stock injection system, could take some time to track downt he culprit, sorry I can't offer any real help
Brianppp
Do you think running some injector cleaner would help? I'm going to run some of that later on when I fill up the gas tank. I also plan on seafoaming the engine later. Hopefully that helps... any other suggestions?
Return to “Datsun Z Forum”
