I was fortunate enough to have recently purchased a 1981 Standard Cab 720 with a remarkably low 28,000 miles.
Truck has some stumbling idle/off idle issues, which through this site I have informally diagnosed as vacuum issues (all original hoses.)
That aside, the truck runs absolutely great.
Anyways, she's got a ticking lifter. I can't honestly say with 100% certainty whether or not the truck has been ticking since i purchased it last week. It's one of those things i may not have noticed right away, but now that I've noticed it, i can't UN-notice it.
I've got the Haynes manual, which I'm pretty disappointed with compared to the Bently guide I had for my VW. It just attempts to cover such a huge spectrum of Nissan vehicles that it seems to refer to the original owner's manual and lacks some of the specifications and specifics that i require.
I'm assuming that the z22 still utilizes solid lifters. Could the lash need adjustment at 28k miles (I'm 100% sure it's legit. The title i received showed the truck as having 3k miles in 1991!) or could it be something as simple as varnish or carbon making the lifter stick?
I searched for ticking/sticking/tapping with little luck, so I'm assuming lifter/valve tap is NOT common with these trucks. What should my first move be? I don't want to risk the sticking valve being on the exhaust side and burning it (The truck has so much more life to live!) The tapping is VERY light, i only first noticed it one night when i sat in the truck idling and rolled the windows up. I just want to do something about it before it gets worse. My previous vehicle (2001 Jetta TDI ALH) threw a rod at only 73,000 miles, so i'm insanely paranoid about unusual noises.
Do additives, such as marvel mystery oil, lucas, or seafoam work? Or should I immediately tear into the valves with a feeler gauge? I've only ever owned vehicles with hydraulic lifters, so to be honest i'm not 100% confortable with valve adjustment, so I'd be out a few shop hours.
Anyways, thanks very much in advance, and thank you for the great forum.
Pic for views:
Edit:
I changed the oil and filter with 10w30 as soon as I noticed the ticking, and after about 60 miles or so, it hasn't stopped.
