evildky »
https://forums.nicoclub.com/evildky-u13100.html
Tue Mar 25, 2008 4:27 pm
well then you must be missing something, sometimes you can't see the forrest for the trees, I should know I have loads of embarrasing stories but we'll skip those for now, fixing fuel leaks shouldn't require replacing fuel injectors just the seals at the bottom or the hose at top?
fuel pump coming on? staying on? injector relay clicking? injectors firing? power at the coil? spark coming form the coil? spark coming from the individual plug wires? plugs sparking?
as fro the tem sensor, it's actualy the CHTS and on the n/a I beliee it's located int he bottom of the thermostat housing, on the turbo's it's located at the base of the head between the spark plugs for #5 and #6, ewither way it's a standard bosch 2 pin injector plug and it would cause excess fuel possibly fuel fouling the plugs
