1981 Datsun 720 SR20DET
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
shakercrouch
Car: 1981 Datsun 720
1987 Chevy C10
Hi Everyone,
Constructive Input Very Welcomed Especially on the Wiring :crazy:
Working on my project truck again. Its been years since I`ve posted anything and now that I`m actually into the build again with my new to me SR20DET.
I had the Motor and Transmission Installed at a friends shop to get it sitting level and Square in the truck. I have a Wiring Specialties Harness for SR20DET for All Datsuns. I had them send it with what they call Flying leads ( All the wires need to be spliced in ) Under the hood the Connections hooked up great, Lengths were right, In all very happy with the Harness.
For a wiring block I picked one of these from a guy over on ratsun.net ( http://community.ratsun.net/topic/28097 ... more/?st=0 )
Here is a list of parts I have acquired for my build thus far
JDM nissan SR20DET S13 Black Top Complete w/5 Speed
B&M 45088 - Precision Sport Shifter
ARP SR20DET Flywheel Bolt Set
Complete Belt Set SR-S13
OEM Timing Chain Kit
Coolant Temp Sensor
OEM Clutch Master Cylinder 240sx 89-98
Genuine Nissan OEM Oil Filter 15208-53J0A x2
ISR Performance Adjustable Engine Mount Set
OEM Trans Mount
OEM Front Main Seal
OEM Rear Main Seal
mishimoto Radiator Package w/Dual Electric Fan
OEM 300zx Fuel Filter
OEM Water Pump SR20DET
Megan Racing Stainless Steel Downpipe 3"
Megan Racing Silver Pulleys
Megan Racing Turbine Outlet
Walbro 255 LPH Fuel Pump
intercooler Hotpipe w/HKS BOV Flange
OEM Coolant Temp Sensor
EXD06950B Stage 2 clutch cerametallic kit S13
FDZ143221 Fidanza flywheel S13S14 w/ SR20
MMODP12125B mishimoto magnetic oil drain plug
N.O.S ClutchSlave clutch slave cylinder 240SX
YMGK009 gasket kit 91-99 SR20DET
Datsun CanAm Wiring Box
Here are the pictures but there are more here https://goo.gl/photos/fYbUNm7gbY9wcUou8 -
Loaded up and heading home
My Daily towing my SR720DET
SR20 DET W/Radiator just there for the Picture!
Down Under
Wiring Specialities Harness & Wiring Box from Ratsun.net
B&M
shakercrouch
1987 Chevy C10
FYI - The parts list has clickable links not sure why and they make no sense
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
shakercrouch wrote:
Sun Jul 16, 2017 6:27 am
Links you're referring to are not showing on here. It's possible you have something like VigLink attached to your browser, which automatically loads link suggestions in your web browser. Go to http://www.viglink.com/opt-out/ to disable it.
shakercrouch
1987 Chevy C10
Thnks Rogue One! Got that turned off :)
Return to “Datsun 720”
