evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon Apr 20, 2009 5:33 am
the radiator should be available form any parts store or radiator specialty shop, it most likely interchanges wiht the 280zx
intercooler!? you do know that an intercooler is only used on turbo cars, it would serve no purpose and offer no benefit on an n/a car
rear axle, I believe the 810 got the R200 so no benefir in changing the axle, and yes some years are pretty much the same as the 280zx, and the cv shafts should swap right in but you might need the companion lage as well, the brakes I think you'd have to swap the trailign arms form the 280zx, the maxima would likely be a better donor as the brake bracksts are bolted on
L28 yup, direct bolt in replacement for your L24, you could even swap in the L28ET, then adding an ntercooler would be sueful
seats, anythign fits, just gotta modify the brackets, miata seats are nice
