Perrenial Badass »
https://forums.nicoclub.com/perrenial-badass-u98460.html
Fri Sep 25, 2009 7:03 am
Yea, the link to his year is only about an inch above your post.
Get the manual if it is a Haynes. I got a Chilton with my 73 and it is crap, and though I haven't got a Haynes for the S30, if it's anything like the Z31 book it's a LOT better. The Haynes walks you through stuff more than the FSM does so it's good to have both references. Plus, unless you want to print out the FSM, you might end up running in the house every 10-20 minutes to check s*** (like I do when the Haynes is "on vacation"). And that usually ends up being a bad idea for your carpet. My carpet is white, I know what that can lead to unfortunately.
