Postby
KiddysClassics »
https://forums.nicoclub.com/kiddysclassics-u248859.htmlFri Mar 06, 2015 11:36 am
This vehicle, which has always resided in Florida is in excellent condition compared to other Datsun 240Z's which are often found rusted out. The owner bought this (nearly) rust-free car as a project destined for a performance build. Being mechanically inclined, the customer is going to be doing all the assembly and upgrades but wanted us to take care of the body restoration.
Postby
KiddysClassics »
https://forums.nicoclub.com/kiddysclassics-u248859.htmlMon Mar 09, 2015 10:44 am
When we stripped the paint from this vehicle, we found no visible rust and very little body filler. Those who are familiar with these vehicles, will tell you that finding an almost rust-free Datsun 240Z is near impossible.
Postby
KiddysClassics »
https://forums.nicoclub.com/kiddysclassics-u248859.htmlFri Mar 13, 2015 12:05 pm
Compared to most other vehicles that come in, media blasting this 240Z was relatively quick and easy due to the lack of rust. We did find some areas of mild concern that we will be repairing.
Postby
KiddysClassics »
https://forums.nicoclub.com/kiddysclassics-u248859.htmlMon Mar 16, 2015 7:34 am
These openings in the firewall were originally made to allow the HVAC lines to be run inside the vehicle. Because the owner no longer intends to use them, we fabricated patch pieces and welded them in.
Postby
KiddysClassics »
https://forums.nicoclub.com/kiddysclassics-u248859.htmlWed Mar 18, 2015 8:24 am
Upon inspection of the rear valance, we noticed that the panel was being pushed up between the spot welds - which usually indicates that there is rust beneath the surface. After carefully removing the rusted panel, it was media blasted, repaired and re-installed.
Postby
KiddysClassics »
https://forums.nicoclub.com/kiddysclassics-u248859.htmlThu Mar 19, 2015 7:35 am
While inspecting the vehicle, we noticed a large rust hole under the cowl. We scraped away the seam sealer and revealed a significant amount of damage compared to the rest of the vehicle. We removed the HVAC duct and repaired it and the surrounding area.
Postby
KiddysClassics »
https://forums.nicoclub.com/kiddysclassics-u248859.htmlWed Apr 01, 2015 9:25 am
The rear wheel well on the passenger's side was badly rusted. We cut away the damaged area and fabricated patch panels to replace it. Currently, we're working on ensuring the contours match the factory look.
Postby
KiddysClassics »
https://forums.nicoclub.com/kiddysclassics-u248859.htmlMon May 11, 2015 7:33 am
Although these frame rails were not in horrible shape, the owner of the car has decided to replace the original rails with thicker aftermarket rails to make the body stiffer to support the additional horsepower the car will have once complete. Our job was to make the new frame rails replicate the original to maintain the overall stock look the customer wants to keep.
