1969 Datsun 510 turn signal problem?
Discussion forum for the venerable 510, and its non-US counterparts, the Datsun 1600 and Bluebird.
msjgonz
Car: 1969 Datsun 510
1971 Datsun 521
So I recently got a new turn signal on eBay for $10 but I noticed that it had two extra pins. My old turn signal was 4 plus 1 for the horn. I decided that I should take all of the wiring and stuff off of both and put the old wiring into the new turn signal as it doesn't wiggle around. I disconnected the battery of course. I believe that something is very wrong as when I plugged the battery back the horn when off. At the moment I disconnected the turn signal connector and horn wire. I believe that something is loose? I installed everything as I remembered. Does anyone know why the horn goes off? Does anyone also have a picture of a turn signal?
Note: Car is a 1969 Datsun 510 with an L20b
-Thanks!
Welcome aboard!
Something sounds fishy - A turn signal for a 510 should cost WAY more than $10 (can you post a link to the part you bought, or a picture)?
Also, if you reinstalled everything by memory, you obviously got a couple wires mixed up - the horn probably got connected to a "hot" wire rather than a switched terminal.
Let's have a look at what you're working with so we can clear this up for you. :)
Return to “Datsun 510 / Bluebird”
