tiniestgarage »
https://forums.nicoclub.com/tiniestgarage-u239001.html
Wed Jul 23, 2014 2:28 pm
Hey folks.
First post, new owner! I searched around and wasn't able to find a solid answer.
My little truck started stumbling on acceleration - just the first couple of seconds once you hit the throttle. I gave it a full look through - replaced plugs, wires, cap, rotor and fuel filter as it needed to be done anyhow.
I noticed that I can see the fuel pressure surging in the filter. It fills to 70% full then falls to 50% full over and over again about every 4 seconds. I assume the pump is my problem.
Having no experience with mechanical pumps, does it make sense to convert to electric and move the pump down under the truck on the frame? Can i just leave the old pump sitting there unplugged?
Thanks in advance - I love this little truck!
