1964 L320 pick up
General discussion forum about all things Datsun! NOTE: If your thread is specific to a certain model, please make sure you post it in the proper forum.
zenndog
Car: 1964 L320
Well it is late and the wife and kids are asleep, i broke out the Laphroaig and started to ead more and more of all these datsun forums i have found and signed up for and..... well heres the scoop.
I just bought the first car/truck I have ever purchased off of ebay, if i hadn't pulled out the scotch i would never admit it! The truck is a datsun L320. I a picking the truck up tomorrow and i can't wait to skin my knuckles onit. Here is a pic
The truck is suposed to run well but the brakes don't work, guess i will find out.
wish me luck and talkto you all tomorrow night!!!
LilDat
Car: Datsun NL 320, Datsun U320 (the runchwagon) 1972 Datsun 510 wagon
That truck has been on there twice. What I'm seeing looks good as far as the body goes. Hope your bed is good, I spent a fortune on mine. The brakes shouldn't be a big deal. Keep us posted on your progress and switch to burbon, Ezera Brooks black, and use it only to celebrate fixes on your truck! Course you could always carry a bottle with you and when the truck hits multiples on the speedo stop and celebrate! 55,555;66,666;77,777............ Had an old econoline pickup I did that with and she lasted forever! Welcome aboard Zendog. Ken
IMH
I recall seeing that truck on eBay.  Wasn't it in Fullerton?  And it included an extra E1 engine and what looked to be a R16 (Datsun roadster) engine and a trans that I wasn't sure which it was.  And lots of parts and literature and a fairly nice interior IIRC.  Didn't it have a sunroof or was that just my imagination?
zenndog
Car: 1964 L320
IMH,
     Yeah, that was it and it does have a sunroof which is kind of a bummer, although it seems to be installed well, I dug into the brakes the other night and i took lots of pics. I should have snapped a better shot of the sunroof.
LilDat,
     The bed looks good, there is a dent on the rear driver side but the cargo area is used but no rust out, just surface rust in the worn areas.
[IMG]http://i301.photobucket.com/albums/nn70 ... tsun11.jpg[/IMG]
zenndog
Car: 1964 L320
dat521gatherer
nice score, i wish i had a 320. how about a interior pic?
zenndog
Car: 1964 L320
dat521gatherer
awesome it looks great. i also have a pic of my truck doin 40mph with nobody in it. is that an original gas pedal pad? the 521's came stock with no pad.
zenndog
Car: 1964 L320
I have no idea if the pad is original,  I just went out to look at it and I think it was not, I think I have seen pedal kits for roadsters that had the three pads like are on my truck so maybe they are for a different datsun vehicle. The gas pedal pad kind of rides up over the bar which supports the pad itself so I doubt it is designed just for the 320 pedal.
IMH
[user=489]dat521gatherer[/user] wrote: [quote]awesome it looks great. i also have a pic of my truck doin 40mph with nobody in it. is that an original gas pedal pad? the 521's came stock with no pad.
[/quote]
My truck shows 0 mph with nobody in it but it does show that it's overheating when it's not running:).  320's also came stock with no gas pedal pad.
zenndog
Car: 1964 L320
Warming up for the drive into work,
[img]http://i301.photobucket.com/albums/nn70 ... 0_3075.jpg[/img]
[img]http://i301.photobucket.com/albums/nn70 ... 0_3076.jpg[/img]
Just thought I would throw up a couple current pics, I think most of the pics above are still from e-bay.Zenon
LilDat
So, did you get there and back again without incident? If so "high-five"!:)
zenndog
Car: 1964 L320
I have been driving it for about two weeks now.
I love it.
Collecting parts now to redo the king pins, they are loose.
I had to rebuild the clutch master and slave, still not disengaging clutch completely, the master had some shims between it and the firewall , I think I need to pull some out to get a little more travel.
The shifter it finicky, shifts great sometimes and stubborn others.
Burns oil, probably worn out in general but I may rebuild head to see if it helps.
Been trying to find a remanufactured J15, found a couple places on line but when I told them it was for a truck they got all weird, Haven't heard back from them.
mklotz70
check the factory manuals for the spec.....you'll have to ream the new kingpin bushings for the pin to fit.
I did a write up over a year ago when I did the 521....here's a link to the thread on nwde.....
http://www.nwde.org/extras/forum/forum_ ... =4234&PD=1
hope it helps. :)
dat521gatherer
i still run with king pins. there not as bad as some people make them out to be. although one time i couldn't get the lock pin out (tappered bolt thing). i  noticed that it was easier to put the shims in first and tap the beaing in last rather than vise versa.
hey mike sorry i havent bought your 521 2mm hub shims yet. slow and lazy. too many projects going.
mklotz70
No prob....there's several sets just sitting on the shelf.  :)
Return to “Datsun Chat”
