19 X 9 Rims on Q45
AGM
I have purchased 19" MAK Sting wheels for my 1994 Q45.
http://www.makwheels.it/catalo...od=24
The 19 X 8 on the front are no problem.
The 19 X 9 on the rear, only have a 35 positive offset. I need at least a 55.
If I can't get a 55 offset, I may need to shorten the axles.
Has anyone ever shortened the axles on a Q45?
I am concerned about the safety due to the shift in the centre of gravity ect.
Regards
AGM
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Seems like you will need to mount a 255/40-19 on front to achieve the minimum load carrying capacity required. Unfortunately, they are 1" too great in diameter relative to stock, so they may rub on even a stock ride height suspension. Tirerack (Michelin Pilot Sport) recommends a 9" rim width, with the range being 8.5" to 10".
The correct diameter 255/35-19 are almost 200 lbs. insufficient in capacity. The 285/30-19 show as having only 1477 lbs. capacity at a maximum inflation of 51 psi, so they are under specification also. If not a misprint, they would work on the rear.
How heavy are the rims? How strong? Might only be suitable for parade duty. With 17" or maybe 18", you should be able to acheive proper tire load carrying capacity.
Hope you kept your receipt....
The 10" wide rims that the JDM guys use with widebody kits are only possible through spacers and longer wheel studs, a stupid move IMO.
Shortening the axles may not help either - Looks like a lot of effort for minimal to no gain, AND a potentially fatal change in rear suspension geometry.
Why not go 18x8 all the way around?
sijoko
Car: Black 1994 Infiniti Q45 Turbo, Pearl White 2014 Maxima Sport
The cheapest route would be to have the fenders rolled by a good body shop. You could also increase negative camber and watch your tires get destroyed.
Is the car lowered? If not, 35mm might work.
I test fitted 17 x 9.5 (offset of 36mm) w/ 255/45 kumho ecstas on my car. I had to adjust the camber a bit, but it was not excessive. My car is lowered with Eibachs.
So I would think that a 9" rim w/ 35 offset should be workable. The biggest factor is the width of the tire.
AGM
Thanks for the reply's guys.
I have decided not to touch the suspension, as it is far to dangerous. Potentially fatal.
If I can't get a 55mm ofset, I will just go 19 X 8 all the way around. I have a very big spare parts collection now.
Regards
AGM
AGM wrote:I have a very big spare parts collection now.
Too bad your garage is in Australia :(
AGM
While searching the Web, I came across the 'Wide' Body Kit be evolution.
I am thinking about adding the Fender Flares to my Impul Body Kit.
Does anyone know of any other fender flare kit available for the Q45.
Also, I will not have the negative camber as in this pic.
http://www.evolution.co.jp/exc....html
Regards
AGM
Need4Speed
Car: Unique Cars, Sailing, Shooting sports
Hey AGM,
I LOVE Impul's grill for the 90-93's......I want one bad. However, when I last looked on their site it looked as if they wanted over 1.5k USD! :eek: Do you know if that is correct?
Thanks,
Andy
Also try ADMIRATION
They have 2 90-93 options and 1 94-96 option.
DAEDALUS
Car: 1990 Infiniti Q45
Fortunately the Japanese seem hell-bent on destroying their currency to keep their exports up. Loans there can be had at virtually zero interest. But the dollar must fall, and has been. Buy your body kits and Sonys soon!
Mmmmm - I'm liking this kit:
Anybody know what 300K yen equals in USD?
DAEDALUS
About $2500 give or take, plus taxes, tariffs, shipping, etc.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
AZhitman wrote:Mmmmm - I'm liking this kit:
That front spoiler could scoop-up loose marbles that car is so low. Must be no springs on that car.
__________________Brian1995 Q45 & Q45t
nlzmo400r
Car: '02 Nissan Altima QR25DE
'93 Nissan 240SX hatch KA24DE
maybe even bagged, its probably strictly show
AGM
Need4Speed,
I know Impul is very expensive as I bought the 1994 Body Kit.
The price on the 1990-1993 Grill could be right.
Get your local Japanese Speed shop to get you another quote.
Hope this helps.
There is also the Admiration Black or Silver Grill.
Regards
AGM
