19" x 9.5" rims, what tire sizes?
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
batman0505
Car: 2005 G35 coupe, 6MT
I can get 2 rims with a +45mm offset, and 2 wtih a +25mm offset. Throw the 45mm offset rims on the front, and the 25mm offsets onto the rears? Or just go with the same offset all the way around?
I am thinking:
255/35/19's on the fronts and285/35/19's on the back
What do you guys think?? What combo? Spacers?
johnparkyourcar
Car: 03 DG coupe 5AT
are you gonna get staggered or same size for all 4 corners? I'd say 25 offset will be fine. 45 is too conservative.
johnparkyourcar
the most common size used is 245/275 but thats with a staggered setup
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
