19" Wheel Recommendation?
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
consultant1027
Trying to see about some 19" wheels for G35x. Plain silver, no chrome, no black or colors. I would think the best bang for the buck is some used Infiniti 19" wheels but most of them are from the S models which have staggered setups with different widths in front and back. X has to be the same size front and back.
Any other suggestions as far as OEM looking aftermarket wheels that are decent quality for low price and don't look ghetto? And of course have the right offset as I'd like to avoid spacers. I'm assuming on an 8.5" (1" wider than stock) it would have to be at least 40mm offset or else it will not clear the brake calipers - suppose it depends on the design of the wheel though.
biggie
The G35 Sedan had optional non-staggered 19" didn't they? Or was that just 18" that looked like the 19" Coupe wheels?
Could look into M or FX wheels?
audtatious
The G35 sedan never had a 19" wheel option. They have either staggered or non-staggered 18" dependent on the year.
suby01
Car: 2007 Infiniti G35x
you cannot run staggered on your X. as far as factory option the new 370z wheels look amazing on the g sedans. you would need to get 4 fronts to fit.
or the new maxima nismo wheels are the second best choice for oem.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
