They should fit fine. I have 19x9.5 all around +40 offset. Idk much about what tire size for sure. Mine are 235/35 falkens. They're stretched no buenoEric Noa wrote:Hey guys Im in the process getting new rims for my A/C. I found a set of Vossen VVS 75 for a great price and I wanted to know if they would fit my car.
Front Wheels and tires.
19"x8.5" - 45 offset w/ Falken FK452 - 245/402R19
Rear Wheels and tires.
19"x9.5" - 35 or 45 offset (Im not 100% sure) w/ Nitto Neo Gen - 275/ 352 R19
Thanks for the help. Also if anyone could tell me how much these wheels weight I would appreciated it. I have search online but can't find
anything.
Im buying these used from a friend and he had them on a G35 and thats the setup he had. I would definitely change the back tires to a smaller size. What would be a good size for the front and back?wade001 wrote:Sorry if I sound negative but why would you be putting 275 tires in the rear on a FWD car???
Thanks... my main concern is the weight of these wheels. I had 20" Petrol Octane and I took them off because the weight slowed down my car a lot and made it feel heavier. The petrol wheels weighted about 60lb with the tires. I weighted the stock rims with tires and they weight 50lb. I have been searching everywhere but I can't find the weight of these Vossen wheels.wade001 wrote:I think 245 all around is good and all you need, but they will look different because of the widths from front to back. maybe 255 in the back would look good.
I looked up the front tires and they weight 25lb. I couldn't find any info on the back tires. I called the manufacture and they couldn't give me a specific weight for the rims because their discontinued but the guy said about 26 for the front and 27 for the back.wade001 wrote:yah, heavy wheels kill accelleration. plus sizing is working against you, even if they may be a little lighter. people forget that they should consider the tires as well, bigger tires=heavier. my stock 16" weigh 45ish lbs.(on my scale) someone said 35 but i didnt believe it because thats the weight of forged racing rims/tires. cant find the weight of them either. but they probably are not light, with wide tires i see at least 50lbs and probably more.
wade001 wrote:thats not to bad, 245/40R19 will be around 26-30lbs.as well as the 255s, you can do the math lol
