SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Sun Mar 26, 2006 4:56 pm
8.5" wide +35 offset will sit nicely, but will hit your coilover if your car is too low.
Hopefully you have a coilover with a tapered lower spring perch. That helps clear wide stuff. You cannot have your ride height dumped. The location of the lower spring perch is dictated by ride height with adjustable height and adjustable preload coilovers(most of the good and really good brands), so if your car isn't dumped, you can gain more clearance for bigger and wider wheels.
You could do spacers, but run a search on wheel spacers to see what people think of them.
