19 Inch Varrstoens FITMENT QUESTION! WHEEL GURUS ASSEMBLE!
P3ngy
Car: 1994 300zx Twin Turbo(Sold)
1992 240sx (Sold)
Supra Swapped 95 E36 M3 - (Sold)
93 240sx (Daily Beater/Slider)
So I bought the Varrstoen 19/9.5/+22 and 19/10.5/+22 setup...
I've seen the (Before Tdog rips my a** for not searching) 18 inch Varrstoens sit on the 300zx with nothing but 1.5 inch drops..
And I've seen Steven's 300 - but dunno how to get in contact with him or if he still posts..
(We're actually from the same area)
post5860510.html?hilit=varrstoen#p5860510
My question is... You guys think I'd be able to make his exact tire/rim setup work with just Megan coilovers, and rear camber arms?
Think I can get away with not rolling my fenders? Not sure if he did or not...
I suck at suspension/wheels. A lot.
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
Will def need a roll on front and rear.
McLarenF1Kid posts more on 3ZC. He did a ton of work on his fenders to get his absurd wheels to fit.
Z-owned
Car: 93 N/A Z32
90 VW Corrado
01 mr2 spyder
2nd Steven's fitment has required alot of work to fit it with pulled/rolled fenders along with camber. We aren't talking just a slight pull either.
Z32TT
Car: 90' 300ZX TT
You have a TT, it will be alot easier to fit these on the rear. Btw you need front camber arms and def tension rods
All fenders rolled, no pulls here
19x9.5 +4 19x10.5 +15
235/35/19 2* camber
265/30/19 3* camber
P3ngy
1992 240sx (Sold)
I appreciate the input guys, sorry for the un-speedy response, being in afghanistan and all - pretty much got the 3 members I was looking forward to responding...
So a list for all of the suspension parts I'm going to need??
Just all new tension rods and front camber arms?
Again, please keep in mind that I suck at wheels - so if you start going into degrees and the differences in rolls and pulls I probably will just act like I understand rather than admitting I don't.
I have a friend who offered to heat up the fender, and do a slight roll if need be...
Should I go ahead and buy some 20mm spacers for the front or will they look alright without?
Thankyou guys for all the help in advance!!
:monkey:
PS. Can I get some links for all the suspension parts I'm going to need besides coilovers?
And how exactly does rucus effect wheel fitment??
Z32TT
Car: 90' 300ZX TT
fuca's and ruca's adjust the camber
Parts you need at minimum
fuca's aka Adjustable Front Camber Arms
ruca's aka Adjustable Rear Camber Arms
& adjustable front tension rods
This page http://www.powertrix.com/agoracart55/ag ... Suspension has all those parts listed, you dont need to buy from this vendor as there are many, but to give you an idea. This vendor and SPL however are very good, I opted to go a tad cheaper with Wicked ruca's and tension rods, but have SPL fuca's. I suggest staying with the +22 and not run a spacer, you will prob like where it sits at that offset for now, also get all your fenders rolled as well as figuring out what tire sizes you want. Adjusting the camber arms will bring it closer to the fender or away, depending which way you adjust them. I suggest an alighnment after install though.
BigTDogg (MA)
What he said.
P3ngy
1992 240sx (Sold)
Thanks guys, perfect replies - as always you'r up mostly helpful, I'll be sure to post pictures when they are on - and make sure you see the work of your 100% input!
