:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Wed Sep 07, 2005 2:46 pm
For a stock body...
9" front will require MAX of +25 to clear coilovers...I'd run +15, and you'll be able to use 245 width tires easily...255's as a max.
For the rear...to match a 9", +15 front wheel...you'd need a +28 on a 10" wide wheel. That will require a couple degrees of camber a fender roll (no pull)...pretty simple to fit.
FWIW, on my S14 - I run 17X9, +25 on all 4 with Tein HE...235 front tire, 255 rear...fits fine. I used to run 245/40-17s on all 4, so you know you can use 245s up front, especially if you order with less offset than my wheels.
- Brian
