he may not be a JDm tyte drifter that drives his 600hp drift machine around like all of you other uber cool guys....Dizel01 wrote:I have a slight stretch on my 18x9.5 using a 235/40/18 Federal 595s (those tires run wide). 245s would be what you want. As for 18x11 my brain can't comprehend anything but stretched sizes on that. May I ask why you want such lame tires sizes? You goin uber wide body?
it is now.simmode1 wrote:
And why isn't this in the Wheels and Tires forum?
needs more meat.Darius wrote:With that said 245/40 and 295/35. Done.
The OP has an S13 listed under his avatar. Offset is very important because it will determine whether or not any proposed combinations will clear his suspension and whether or not it can fit under stock fenders.Darius wrote:I don't understand how wheel offset correlates to tire width recommendation. And you do not need to cut fenders and add flares/widebody panels, etc. to fit an 11-inch wheel. A solid 3/4" pull and you can fit close to a 12-inch wheel out back. This is for an S14 anyway. I'm not sure how an S13 would work out.
Not disagreeing with you but... geez! Such huge staggers!Darius wrote:Fitting the tires inside the wheel well aside, I stand behind the 235 and 295 combo. 245s and 305s will bulge just a little bit.
265/35/18295/35/18but....from the way you describe your set up why are you getting 11in wide wheels in back? you have 0 camber so you're obviously on stock suspension or subtle lowering springs with a 300 degree camber kit and you want to stagger your whees from 11 down to a 9.5? good luck ever turning, your wheels may turn but your cars gonna go straight. you can fit 11's in rear on stock fenders at 0 camber if you just sit at stock ride height but your car is gonna look like sin. if you absolutley have to run an 11 in the back then run a 10 in front and tuck your wheels apropriately with a proper drop and camber. and if you drop and camber your going to want to stretch tires to clear fenders. but thats just my opinion, if you want your car to look like a monster truck on baller a** wheels go for it, to each their own.FUJIBAYASHI wrote:What tire sizes should I get? I do not want to stretch at all and ZERO camber.But I would still like to have a low profile tire.
completely agree. i have a 17x9.5 with 255/40 and its almost perfect. i plan to run 275 in the rear on the 9.5pandapants wrote:
needs more meat.
255/40305/40
i did that once... had ridonkulous grip in the back but it was too fat and rubbed my fenders due to my ride height. but if you're gripping then by all means run a 275 on a 9.5.Beems240sx wrote:
