18x9.5 +20 all around
jays240
Car: 240sx
will they fit a s14 with z32 in the front...? and if they do...? will the fender clear the rims...? or are they gonna rub each other...? thanks alot...!
*20mm front fender*just bought tanabe coilover...will put them on before buying wheels*i have tanabe springs/kyb shocks on the car now
Modified by jays240 at 3:19 AM 10/23/2007
cmfireman
Car: '96 Nissan S14 SE
Offset and width is not a determining factor in clearing Z32 brakes.
It's all about the wheel design itself.
Anand
Car: 95 Nissan 240SX
depends on what wheels
but taht offset and width is not aggressive at all.
especially when you get 20mm front fenders.. you will look sunken in. you should get some 20mm spacers to push out the wheels so it looks flush
Turkishs14
more then likely yes, I had to roll the fenders on my s14 to put 18x9.5+30 so yeah.Front is most def going to rub
whiterps13
Car: white LE hatch
Turkishs14 wrote:more then likely yes, I had to roll the fenders on my s14 to put 18x9.5+30 so yeah.Front is most def going to rub
READ. He has 20mm fenders.
No they wont rub and just like Anand said they will be sunken.
adrianfromthecastle
Car: 1992 Nissan 240sx
cmfireman wrote:Offset and width is not a determining factor in clearing Z32 brakes.
Anand wrote:depends on what wheels
dial in some gangsta camber, and you should be ok...
take off the 20mm fenders and go back to stock
whiterps13
Car: white LE hatch
haha
