18x8+30 on a kouki
edm-s14
Car: kouki
what size spacer will i need to clear stock suspension with lowering spring
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
nissan-tires-wheels-brakes-suspension.html
Should have all the info you need.
Welcome to NICO!
kouki munster
Car: 97 base 240
Let me guess, these wheels:
Even if those are not the wheels you want to run(they are 18x8 +30) you will not need any spacer to fit them with any shock/spring setup or coilovers.
BTW, that is my car and I don't have spacers.
audtatious
G35 18's are also 18x8 -30mm
edm-s14
Car: kouki
kouki munster wrote:Let me guess, these wheels:
no there no the one the are the g35 oem wheels the 7spoke ones
edm-s14
Car: kouki
Found out what the problem was it was a bent strut called Jeff at 240sxmotoring and he said to measure them, and the passenger one is about.5" longer then the driver side. Doesn’t sound like much but that is why it was sitting on the tires. Driver side was fine, so getting a new strut tmw and a small slip on spacer just cause I don’t like hoe close the in side tire is to the inside of the strut.
Thanks for the info guys!
StockAsFuhS14
Car: Bone stock S14
maybe mention that you hit a few curbs when your were out driftkar'ing next time you have wheel/suspension issues lol
Hijacker
Car: '92 240sx Convertible
'94 F-150
Why would you bump a 2 month old thread to troll someone :tsk
