sjbsuperman1425 »
https://forums.nicoclub.com/sjbsuperman1425-u80456.html
Fri Oct 23, 2009 4:28 pm
thanks for the link, i've been searching all day and didn't find that. is the ring gear only stamped with the ring gear count or does it have both the ring gear and pinion gear ratio stamped on it?
according to my math the stock 89 S13 is a 49:12 (4.083)..so thats a negative on switching the ring gear if its a 4.36. I could switch the VLSD internals over to the open diff pumpkin and use the stock ring gear and retain the 4.083 right?
also, from what i've read throughout the day is that the 4.083 JDM VLSD's were ONLY 5 bolts. Can anybody confirm this?
Thanks alot everybody, I've been searching for answers all day since 1pm.
