gumby74 »
https://forums.nicoclub.com/gumby74-u53716.html
Fri Jan 15, 2010 3:55 pm
IF you are creative enough, and IF you can find the appropriate size bulb sockets to go into the light housings, and IF you have a simple understanding of how the lights operate you can wire them up yourself.
Some wire cutters, solder (electrical tape if you absolutely must) and the right pigtails, you can knock 'em out in a matter of minutes. I believe one bulb runs an individual power wire (constant), the other runs the high (flasher), and both share a common ground. If that made any sense to you, the hardest part will be finding the right sized sockets.
