180sx Power Steering Help.
Josh_sil80
Car: Nissan Sil80
Right, couldn't find much all over google, so need your help.
180sx, originally hicas, I changed the pump, put in a lockout bar, and pulled the lines out, and blocked off others.
and yes I know I can just join the lines but id already pulled it all out before I knew. Rookie mistake.
I pulled out too many lines when I removed it all (first time doing it dont judge me)
All I need to know is if I have my high pressure line in the right spot on the rack? Next to the low pressure line?
I cant remember as its been so long since I pulled it out.
As its leaking fluid from the pump as if its building up pressure or whatever. And I still have no power steering.
any way to clear this up would be greatly appreciated because hicas confuses the s*** out of me. Cheers.
Will upload a pic when I figure out how haha.
