carmo »
https://forums.nicoclub.com/carmo-u91933.html
Sat Jul 26, 2008 10:04 am
Try spraying carb. cleaner into the intake manifold via a vacuum source while someone cranks it over. If it starts and will stay running while you spray the starter fluid or carb. cleaner I would say you have no fuel for sure. You could always take the fuel supply hose off, put it in a bottle and have someone turn the key to the on position. If you have fuel I would say the pump is okay to at least start the car. The get a noid light and check for an injector pulse from the ecu at the injector. If the light blinks then I would say you got some bad gas. If the light doesn't blink then cry because you may need an ecu. Or the ecu isn't receiving a particular signal to turn on the injectors. Crank position or cam position sensor maybe. I dunno, good luck....514
