Have you ever messed with the hks actuator, thinking about getting it for the meantime and getting the greddy boost controller later onflartius wrote: ↑Tue Apr 14, 2026 4:12 amSo either option is going to give the results you want, the question is: how much do you want to spend and what are your end build goals?
On my first 240 I ran a manual boost controller with no issues, on my 180 I have a Greddy electronic boost controller and it doesn't require "tuning" but you have to adjust it until you get the settings correct for the boost you want. The advantage is you can do this without getting out of the car vs. a manual boost controller that will require you to make a 3rd or 4th gear pass, stop get out make an adjustment and repeat. It will also keep you from having boost creep in the colder months when the air is denser, I had to turn my boost controller down during the winter with my 240 but the Greddy opens the wastegate based on the boost it reads.
I've used a compressor with the regulator dialed into the ballpark that I want the wastegate to open at. Pressurize the circuit and adjust the boost controller until I see the wastegate open.
I've never thought to do that, pretty good idea! This is why we pay you the big bucksPapaSmurf2k3 wrote: ↑Wed Apr 15, 2026 2:29 pmI've used a compressor with the regulator dialed into the ballpark that I want the wastegate to open at. Pressurize the circuit and adjust the boost controller until I see the wastegate open.![]()
Hey so thanks for the idea, im almost positive its still overboosting, i did not check to see the accuracy of the boost gauge but its significantly louder spool and my bov sounds like it wants to go on vacation through my hood. I put the hks wastegate actuator on and it has a new vaccum line sourcing directly from a bung on the ic hot pipe. Still over boosting. Took off the actuator and the little arm moves extremely freely, didnt try it but i feel like you could blow on it and move it. wondering if it somehow disconnected from the little trapdoor on the inside of the housing. Either way looks like im having to remove my turbo and checking the internals, super upset since my first track day was supposed to be in 2 months but maybe i can fix/source a new exhaust housing. Any tips at all appreciated, ill try anything since I heard these turbos are a little rough getting out.PapaSmurf2k3 wrote: ↑Thu Apr 16, 2026 2:20 pmThis is why forums are a thing
Also, if you have another person (or get crafty with mounting a camera), you can also verify the pressure on your boost gauge. Sometimes compressor gauges aren't the most accurate.
So hks actuator is on and its still overboosting, the arm that the actuator attaches too moves extremely freely when not hooked up so maybe its disconected from the internal trapdoor, any ideas?flartius wrote: ↑Tue Apr 14, 2026 4:12 amSo either option is going to give the results you want, the question is: how much do you want to spend and what are your end build goals?
So my Greddy controller has a setting to start opening up the wastegate once it reaches a certain boost, the setup instructions recommended about 4psi below your target boost pressure. This is called the 'set gain' for the Greddy unit, I would imagine the HKS controller would have something similar.
