SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Fri Jul 29, 2005 6:05 pm
No not at all. Z31 uses serviceable front bearingsS13 are sealed one pieceAll specs are different
There are a ton of interchangeable calipers onto the S chassis.
You could find that ABS 97-98 S14 calipers and rotors are the same as your 180sx calipers.
If you're just swapping pads into 180sx calipers, use the maxima pads you have listed.
If you need rotors, you can use an early 90's model altima ABS rotors.
