superclarkey »
https://forums.nicoclub.com/superclarkey-u117618.html
Sun Oct 12, 2008 4:31 pm
Hoping you guys can help me, i'm from the UK and not much info here on these.
I have a 1996 180sx Type-S (belive same as Type-x just with SR20DE), bought the car for the only intention to do a SR20DET swap.
Bought an SR20DET Straitcam Redtop out of a 93' PS13 with all wiring and running gear, and fitted it to my car.
Now this is where i've ran into a problem, the loom (wiring harness) that came out of the PS13 does not fit my dash connector under my dash, and looking at it the car side of the dash connecter has a hell of alot more wires then the 8ish wires on the engine loom side ?? There is also an extra connector down by the headlights ?
The dash connector under the dash has alot of fine pins were the ecu loom side of the dash connector has corse connector pins..
What loom do i need for my car and ecu OR do i need to hardwire to the car ??
I have 62 ecu and redtop loom, should i buy a j4 ecu and blacktop loom ?? will this plug strait in then ?
Any ideas?
Thanx,
Clarkey, UK.
