180sx Digital Control
Cyberkreig
Car: 1993 Nissan 240SX SR
I just bought a 180sx Digital AC control. Can anyone out there help me with the wireing? If anyone has the Techspecs or Chilton type drawings for the 240, or ESPECIALLY the 180, I would really appreciate it!
Thanks
Joe
Daunttless
You can't use it with the KA24. You need a SR20 to use it.
Cyberkreig
Good that I've got a Black-Top then :D .
Daunttless
Ah, excellent, when you asked for the 240 specs I figured you meant to wire it into the stock setup. : )
I'll grab ya the specs later tonight and email them to you.
Cyberkreig
Pretty good point there.. I guess I did ask for the wrong specs.. Well, either way.. thanks for the help!
Cyberkreig
Were you able to find any of that information?
SpeedRacer1
Car: 1990 240SX, G35
Hey Daunttless do you have a write up on how to install the 180SX digital CC?
Daunttless
Nah, its not that hard, ya just need the harness with it and wire it into the ECU.
90Nismosx
Car: My car, Movies, Drag racing.
I was just wanted to know why can,t you wire it up to a ka24?
SpeedRacer1
Well if anybody wants one, here is one http://cgi.ebay.com/ebaymotors...&rd=1 I accidently bid on it and really dont want it. It comes with everything you see in the picture. The guy who is selling it is Marco Vargas who had the SCC May cover car I believe. He also runs this store http://www.sr20store.com/ If anybody wants to bail me out by picking this up then by all means be my guest. All youd need is $51.
Cyberkreig
Sensors? The wireing diag. that Dauntt sent me didnt show any sensors on the RHD that the LHD didnt have.. however the relaysetup is different..
Cyberkreig
Gimme your email or get on AIM: message cyberkreig...
Only problem is that the diag. that he sent me says "to pushbutton control" So i dont think its the right stuff.. but atleast it can give me some idea of the relay setup
RedStage
Car: Cars
I had Japanese mechanics telling me that I could not do the very same thing with my CA18DET Silvia.
I had seen someone attempt putting in the digital control and they gave up. All they had was the controller. No wiring except what was already in their CA18DET 180.
Mechanics told me no deal. I thought bull****...has to beable to be done.
First SR powered S13 I found with the digital control I grabbed it and the ENTIRE wiring harness for the AC control.
There was really only one difference between the analog and digital. All the connections fit in to each other and there was on black wire that I could not locate it's destination in the donor car.
I grounded it out, and figured what the hell.....fired it up and it worked. turned out the grounded wire was for the memory function. So instead of the AC being set where I had it when I turned the car back on, I had to reset the temperature and fan controls....big deal.
Not too familiar with the differences in the 240 (like if you guys have the AUTO climate control sensor or not) but I think it should be able to work. To some degree at least. I think that the control will handle what your car can do and that there will be no problems if you don't have the auto climate gear.
Good luck with it. But I highly recommend that you get the entire wiring harness. Might make life much easier.
Xero
Okay, I know this thread hasn't been brought up in a while, but what if you don't have A/C? Does the digital Climate Control require the use of A/C? THANKS!!!
