180sx Blacktop Tach Pinout Missing
sonnyCA
Car: mkIII supra, HB 204sx
Hey guys,
according to the diagram, #3 pinout is for the TACH, but on my 180sx ecu harness, the wire is missing...
What can i do? Am i missing something?
Thanks,
Sonny
Wiring Specialties
Vendor
Sonny,
A late model 180sx Type X will have a different ECU pinout.If Pin 3 is missing, its likely that Pin 2 is yellow/red, which is the tach.
Make sure your ECU is a J4 ECu and NOT 62/E5...If you have a standard S13 ECU, then you will have to repin the ECU plug.
Good luck.
sonnyCA
Thanks bostonS15! I will let you know what ecu i have...
sonnyCA
I have the E5 ecu.
237/0 50F05 A18-C80 G26 5X05
Can someone point me towards the right direction?
Thank you.
