180-200 hp on a budget, no turbo?
Two Fowty
Car: 1990 240sx hatch, 1989 240sx hatch
Right now all I've got, mod-wise:
Injen Cold Air IntakeClutchmasters Stage-5 Clutch (what a PITA for DD) Clutchmasters LightWeight FlywheelEibach Lowering Springs
and then I've got electric fans, which are freeing up a few ponies
This is my DD, but I'm wanting around 180-200hp
My budget: $1500.
What would you guys recommend to reliably get up to my wanted hp range?
I'm not gonna turbo. Be specific in what you tell me, cause I'm kind of a car noob.
Razi
Car: Moo
It will be impossible with $1500.Even with more money, it will be fairly difficult.
chrismo240sx
Car: 92 240sx HB
S13 Blacktop
especially with a single cam motor with bolt-ons. Some definate internal motor work needs to be done buddy. 1500 will probab;y get you all the bolt-ons available and maybe cams, and youll still end up shy most likely.
s14derrick
Car: 1995 nissan 240sx
1500 bucks would be enough for a budget turbo build
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
curious why your not wanting to go turbo, personnal choice or what?
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
your not gona get that much horsepower for that much money without a turbo in the mix..but..with some mods..on the cheep..a little sly shopping ..its possible to squeeze out a 175 to 180 N/A build for that..lets see..
supertech 10.5:1 pistons..... $400ish.BC stage 2 cams.................. $300.ishduel springs and titanium retainers $250.ishnew bearings .......................$45.ishEbay Exaust system $250.ishif ya curbcheck and destroy it..who cares..get another off egay..um ebay.
no need to go forged rods with a NA build..so your not lookin to bad at this point as far as coin goes.
you should see some gains in the upper range and some added torque..with that clutch ya have you should be able to feel it at the wheels..if ya wana realize more responce..change the motor mounts to a solid type mount to limit flex..i my self would use a hockey puck set up..wait..i do use a hockey puck motor mount..lol...good luck..what ever you decide.
David s12
Car: 84 datsun s12 ka24 swap
STOCK DOHC KA WITH M62 SLAPPED ON IT
glitched
Car: 1992 240sx se
IF your serious about making the power, Nistune and some dyno time. yeah, even on a NA.
Two Fowty
Wc240 wrote:curious why your not wanting to go turbo, personnal choice or what?
it's a mixture of things.. first of all I'm 17, and i work at wendys. which means on top of paying my insurance and loan out for my car i have like.. 100 bucks extra a month. so i'm really wanting reliability, cause when things go wrong on my car, i'm screwed unless its a simple fix.
and secondly i have absolutely no knowledge of how turbo's work or what parts are needed to make them function fully. I've read through the threads on here (turbo101, abc's, etc), cause turbo would be nice. But it's really confusing to me, and even if someone gave me ALL the parts I'd need to assemble the turbo, idk how i would do it.
So yea, sure turbo would be awesome, but I really need reliability, and I'm on a tight budget as you can see. Hey, if you can convince me otherwise, and explain what I would need to do to get this turbo thing going, yet have a safe and reliable dd, then go for it, i am all ears. if i went turbo i'd want a small one.
so yea thats why. I'm just really hesitant, and I need this motor to last , cause I cant afford a new one, thats my main concern.
480sx
Car: 1996 Pearl White 240sx
The Ka isnt a honda as far as bolt on mods go. There is no list of things we can tell you to buy that will even guarantee you hit 160 hp. Ka's dont like to make power N/A because the engine does not handle RPMs well due to the design of its crank shaft.
If you want to make power on a Ka, you really need to go Ka-T. Do the research on a budget Ka-T build.
Most popular right now is a Ebay bottom mount manifold, a t2 turbo usually from a nissan, a 8:1 RRFMU for 'tuning', 255 walbro pump, ebay downpipe, ect ect.
Those setups have proven to last.
GODCHSR
Car: 1996 Nissan 240sx
What is wrong with you people...
Get a full exhaust added to that and use a progressive controlled Nitrous kit... FTW!You'd be over 200whp
s14derrick
200whp when you are on the juice! but thats going to get expensive fast if you get addicted as well as the power not being a constant
GODCHSR
s14derrick wrote:200whp when you are on the juice! but thats going to get expensive fast if you get addicted as well as the power not being a constant
Sure but the reality is if he plans on building a bolt-on daily driver he can have a fun fast car for your basic needs BUT if you keep the juice in a safe manner it'll be nice to run your car against some higher league stuff IF the time comes.
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
I would just build up each piece at a time. put 500 dollars in your savings first then start buying turbo stuff. I remember when I first started my quest into cars. I was 17 working at Circuit City... those were the days. Well to make a long story short, you will learn a lot as you go through the car stuff. I look back to when I was 17, 4 years ago, and I knew nothing then.
You can get a cheap T25 setup out there somewhere if you look hard enough. Just get one piece at a time. Like one day a 1 piece drive shaft, then the next some SR injectors, then maybe next time maybe an exhaust and so on and so forth. I figured that all bolt-ons can lead to a turbo anyway. A t25 setup can get you to 180-200whp ish.
...or just get a fresh rebuild lol
Two Fowty
as far as reliability, and turbo'ing, would you recommend ka24e, or ka24de?
Razi
Car: Moo
Both should be the same.
Wc240
97 Nissan 200SX
06 Scion xB
E or DE can come down to a personnal choice. peaple swear to both of em. id say DE. stayin n/a due to budget and reliability needs is a damn good reason. you could go for byuing a used duel cam. then, slowly start buidling it inside out. even with oem spec parts just to have a new motor, while you still drive your car. Honestly, id slowly put money in. make well, thought out purchases. you dont wanna buy a part, have it fail, then buy it again. also to improve your car you can look into weight savings, suspension and bushings,...etc. honestly its up to you in the end. just make sure to research before you buy, and dont get discouraged
urbanskiben
Car: 1991 240sx with 93 motor bored out
Two Fowty wrote:as far as reliability, and turbo'ing, would you recommend ka24e, or ka24de?
ka24de is better and for turbo everyone hates ebay but i dont jus bc its not name brand doesnt mean its not good you might have to do some extra work to make it look better but they do the same for us low buget builds i feel you man loo for a turbo kit on ebay for a 240 and how they basiclly work is the exaughst gas/pressure spins the turbine and then which then spins a connected turbine to pull clean air in and force it through the intake turbo is better bc it doesnt take horsepower away from the engine like a super charger bc of there pully now the oil system on a turbo is probly confusing you how that works is the oil comes from the engine and works jus like a cam bearing and or rod bearing now lets go over where the exuaghts *sp gas goes after it spins the turbine it goes through the intercooler and out that is basic and should help jus look in the tech page and it will explain it more in depth i might have mis spoken on some things but i know it will help bc i was where you where a while back on turbos
DaniMike
Car: 1993 240sx, 1996 240sx, 2008 Altima
omg, not a single period... you are correct tho. A basic turbo build will get you much farther in hp range than add-ons. I do believe it would be best to get better suspension parts first, then work on buying all necessary pieces for a simple t25/28 setup. If you search either here or ka-t.org you should find all your answers. Good luck and don't get discouraged!
urbanskiben
well with the suspension it all depends what you doin with it too and yeah i am geussing you dont have acess to enough tools to blueprint your engine so yeah if you have a question search one of those two and you will find it more than likely and been tired so periods i say screw them for now lol good luck
-RJ-
all the basic bolt ons minus headers can lead to a turbo setup
liquid_cool
-RJ- wrote:all the basic bolt ons minus headers can lead to a turbo setup
the reason RJ and guys like my self..sugest the NA build first..is it is the first step to building a High Boost vehicle corectly..you have to build the internals first..if you incorectly mod a NA build..its not to bad to fix...but a turbo build..would be a disaster money wise...start with the NA build..then when ya feel comfortable about taking the risk...go for the turbo...good luck.
Oneandonly212003
Car: 1990 240sx
on ebay thiers a complet turbo kit for a singlt ka24 for $1,199 and its not hard to install me and my freind did the one on his old motor . hes got RB26dett now
DroptopDrifting
Car: 94 240sx limited edition se convertible
dont mean to threadjack, but if you're lookin for a nice turbo setup on a budget, checkout my for sale thread. i'll give ya a good deal. got a full t3/t4 turbo setup, a safc2, sr injectors, etc. basically the only thing i dont have that you'll need is a btm and a walbro pump. you can have yourself like 260whp reliably for that $1500 you got.
Two Fowty
sounds very nice, but 2 nights ago someone hit my car and ran.. so i guess with my money, i am just gonna fix up the body damage, and work on small problems i have.. and get the car running perfect.
i have eibach lowering springs
macten10
Car: 240sx
The ONLY way you are going to do that with no turbo is spray.
-RJ-
macten10 wrote:The ONLY way you are going to do that with no turbo is spray.
spray is gay
Bigvinnie
Car: 2004 Nissan Frontier desert Runner, 2014 Nissan Titan
480sx wrote:The Ka isnt a honda as far as bolt on mods go. There is no list of things we can tell you to buy that will even guarantee you hit 160 hp. Ka's dont like to make power N/A because the engine does not handle RPMs well due to the design of its crank shaft.
Actually I can guarantee 162WHP on $1100 in parts for a DE engine.
liquid_cool
big vinny is rite..162hp for a de is easy with bolt ons...
as for a cheep easy turbo..i know ill regret telling so many people..
garrett T-3's can be had off of saab 900's all day at a junk yard for 80 bucks..then from there..its a 30 buck egay manifold and 60 bucks in reliable oil lines..you can allso get a egay intercooler for about 45 bucks now..the piping is extra thou..so say around 600 for a cheep turbo set up good for 10 psi...
i do recomend the head,main,rod studs and at least a multylayer steel head gasket.hope this helpd a bit.
Bigvinnie
I always prefer the HX35 turbo biggest bang for your buck turbo. The saab turbo's have a nice quick spool with very little lag. HX35 is slightly laggy but whne it makes mid/high end powewr it feels awsome.
