18 x 9 +15
tooslow240
Car: '91 240sx coupe
would 18x9 +15 fit an s13 with coilovers?granted there will be some rolling needed
heres a pic of the wheel
Modified by tooslow240 at 8:36 PM 4/11/2007
Jbravos14
Car: 240sx S14
They should fit but it cant be to low. because i have 18/9.5 with 255-35-18 on my S14. good luck post pics when their on
URAS
Car: 550hp RB26 in S13 and 450hp rb25 in R32
With a 1"-2" flare of the std gaurds they will fit, but only with a stretched tyre.
we run 17x9.5 +15 all round on our comp cars (some run 18x9.5"+15 rear)
this one has 20mm wider front gaurds and 50mm rear (running 20mm spacers).
spooled240
Car: kouki s14
thought it would be a good time to ask: I have an s14 and wanna run sportmax 006's 18x9.5 in rear with +35mm offset and maybe 18x8.5 +35 offset in front. Will it clear stock suspension without sticking out of the fenders? I'm starting to assume that the stock suspension is very limiting on wheel width...any words of wisdom would be greatthanks -josh
574-240sx
Car: Nissans, Toyotas, Subaru
This is a 17x9 +15. I have stock fender up front with a slight pull. If you are slammed with a narrow tire I can see it working. Also if you are running 18s up front on a S13 you are going to have to do alot of pounding/clearancing.
tooslow240
thanks for the reply and info!
hows the rep of rota wheels? i guess +15 is too low, how about 18x8.5 +25 or +30 up front with coilovers?
i wish i could fit these.
pics c/o subydude
they have this new set called torque R staggered and i was told they make them in 4x114.3's
