18" x 8.5" with 32 offset will it fit my 94 Q45??
Q45dude
Car: 94 Q45
I just wanna know if wheels/tires 18" x 8.5" with a 32 offset will fit a 94 Q45. Tire size: 225-40-18
thanks
Q45dude
Car: 94 Q45
ANYONE!!!????
hannibal
Car: Red Line to Glenmont
The Q45 guys seldom venture in here. But heres a thread with some pics of Wes's set up to get you started.zerothread?id=243555
I suggest asking in the Q forum for more thorough info. There was a huge thread with lots of sizes and pics a while ago. I couldnt find it, but they should be able to point you in the right direction.zeroforum/177
EDIT: found that thread...zerothread?id=223195
Q45dude
Car: 94 Q45
thanks. It looks like they'll fit.
thanks again
szh
Car: 2018 Tesla Model 3.
Q45dude wrote:I just wanna know if wheels/tires 18" x 8.5" with a 32 offset will fit a 94 Q45. Tire size: 225-40-18
Yes, this wheel will fit, although 35mm might be more optimal. The 32mm might be under at the fender just a tad - troublesome with lowered cars, but most likely will work out just fine, particularly with the narrower tire you are mentioning aboe..
However, the above tire size is probably not optimal for that wheel though. I'd use 24/45-18 instead, even if that is not a perfect match for the original tire for that car. My point being that the 8.5" width may be more than the maximum recommended for a 225/40, and a 225/40 may also not have the right load index for a heavy car like the Q.
Check out http://www.tirerack.com to search for specs on your tire.
Z
