BobOB »
https://forums.nicoclub.com/bobob-u231053.html
Fri Jan 31, 2014 3:46 pm
Just found this post and not sure if you've already purchased the vehicle. Before I purchased the JX35, I test drove one with 18" and 20" wheels. Since I purchased the loaded version, it came with 20" wheels. I did notice that the 20" wheels/tires were a bit smoother riding. The bitter issue is trying to find a tire chain to fit the 20" tires. You are not support to put chains on this vehicle, but when you travel over most mountain passes, you can get fined for not carrying chains. I found a set that fit and will put them on the rear wheels if I ever need them. I'd be curious to see what you decided and how you like them.
