I doubt if the speedo would be off. The tires would be a lower profile, so they radius would be the same. With that being said, one would expect a rougher ride but more stability with 19s vs the 18s. I noticed some when I drove one with 17s vs 18s. Not much though. But, 19's have an even lower profile tire, so yeah I would expect a rougher ride.Jeff Lampert wrote:Thanks for your reply. (BTW, I'm getting it with AWD). Does this mean that the transmission and suspension are exactly the same for both the 18" and 19" wheels. i.e. the Touring package does not affect any of this? I was told that the speedometer reading might be off by a couple of miles per hour if the 19" wheels are swapped for standard 18". Does that make any sense? Thanks again.
What possible reason would Nissan have for including larger rims in a Touring package which is about comfort and convenience? The larger wheels reduce ride comfort. It seems the only reason is appearance.jmess wrote:I think you forgot to consider tire and rim width in your assumptions about tire air volume. A 19x8.5 wheel with a 245-45-19 tires has a larger tire/air volume than a 18x8 inch wheel with a 225-55-18 tire. Also we have tire pressure monitoring systems that watch tire pressure for us.
The world is full of risks but you can bet Nissan considers the trade off between ride, handling, and safety when they added the 19s as an option. So there are a lot of reasons not to like or want 19s but the fear factor isn't one of them IMHO.
I didn't forget to consider width, but my description of the problem was not accurate. The problem is not volume alone. The problem is when a 2 under tire loses air, there is little or no ability for that tire to adsorb the blow of a pot hole, and the rim hits the concrete. At high speeds the impulse force that results is huge and the rim will bend, severely in many cases. This is not an opinion. Motor Week as mentioned above, has issued warnings about these tires as well as Consumers reports. Keeping those tires fully inflated minimizes the chance of a blowout. But who here has not experienced losing air totally unexpectedly? Why would thin cross sectioned tires be any different? Couldn't help but notice when I bought my Lexus that they now offer insurance to cover these kind of incidents. Never recall any dealer offering insurance like that in the past.jmess wrote:I think you forgot to consider tire and rim width in your assumptions about tire air volume. A 19x8.5 wheel with a 245-45-19 tires has a larger tire/air volume than a 18x8 inch wheel with a 225-55-18 tire. Also we have tire pressure monitoring systems that watch tire pressure for us.
