Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Wed Apr 09, 2003 9:09 pm
HI! welcome to NICO. glad to see you've searched. Unfortunately, there really isnt any reason to goto 18" wheels except for "show". I dont reccomend it, both from a handling, and a cost standpoint.
anyways, if you want to do 18"" anyways...Use the offset calculator in the FAQ, to clear coilovers you have to keep it less than 5mm closer to the strut than a stock wheel. If you were to run a 18x8 front wheel, I would reccomend below a 33mm offset. For the rear, a 18x9 in a 27mm offset should be fine. Try running a 225-40-18 and a 255-35-18. That setup is very effective, and proivdes plenty of grip in the rear, even for higher-HP applications.
TO be honest, I want to flame you really, relaly bad, mostly because I dont like "FAst and furious" type people who just want the look...but its your car, do what you want. Please looka round, theres more information in the FAQ than most people think.-chet
