18x1118x10SonRebel7 wrote:are 18's too big? it would be nice to run 235/40/18 on a coupe or is this overkill? like some nice rota d2's or so and if anyone has a pic that would be great. 18x9's btw idk if they would fit without rolling and pulling with a 35mm offset on all 4
No no no... Anything less than 9 inches wide in the front is dumb.moso240 wrote:what about on a s13 coupe... i want to stay stock body and not roll or pull my fenders..
im running kyb's with tien springs and im looking to run 18x9.5 rear 18x8.5 front
What should i go offset wise?
Are you wanting to stretch your tires or run max rubber? This will determine what widths and offsets you want...
Sure there is - Retain the original OD of the tire.simmode1 wrote:So apparently, there's noway to aviod an inaccurate speedo w/ 18's...
Great point.AZhitman wrote:Consider that most older car speedos are fairly inaccurate anyway,
No because it only works half the time.simmode1 wrote:
Have you checked your speedo's accuracy since you went with these sizes?
simmode1 wrote:If you have your heart set on 18's for your s13 with minimal stretching, I'd say go with 18x9+22 245/35/18 & 18x10+35 265/35/18.
Thats almost exactly what I'm gonna run, except I'll have 17's up front. Very similar to what Broadfield used to run, as well...
yeah i'm running a 35 series on my front wheels right now and they look like rubber bands, i hate it, i keep thinking my tire is flat.yokota180sx wrote:a 35 series look so f***ing stupid on an 18
yokota180sx wrote:yer so dumb a 35 series look so f***ing stupid on an 18
As I indicated in my first post, I'd rather not use 18's or 35 series tires. But I don't think they look as bad as you two make it seem and they keep you closer to your original diameter. The OP said he's going for non-stretched.phanatikz32 wrote:
