mcheddadi wrote:Weren't you the one who said "you can always add spacers with higher offset wheels but with lower ones you're out of luck"
yes, but this comment was meant for folks that want their wheels flush with the wheel well.
the problem with the spacers is, if you want a flush look, and you get +45 offset wheels, you may need 10+mm spacers to get the look you want. But if you start with +35, and that's not what you want, you may only need 5mm spacere to get the desired look.
also, now that we know that even +25 wheels will fit without rubbing (well, that's what foxmarketing says, but I don't know if that's the case with real, progressive lowring springs like the Eibach)... well, now that we know that +35 offset , 8.5" wheels with prokit will fit without rubbing, there's more wiggle room for folks to add spacers!
So basically my statement still applies, it just appplies with a new starting point for the offset now that we have real world applications that we know will work. In principle, it would still be unwise, in my opionion, to go get some +20 offset wheels and then say... damn, I didn't want them to stick out that far!
