UncleBen wrote:I have 17x8 in the front with a +35mm offset and they're perfect on an s14. For tires, a 235/45 will be run on them. I had 245/45's, but the wall was just too tall.
I'm fixing to have 17x10 in the rear with a +35mm offset as well, which is supposedly going to sit them flush. Most likely with a 275/40, or 35. I'm not sure, I dont want a large wall at all, but dont want a rubber band either.
Why were the 245's too tall? The second 45 number denotes sidewall height. My advice is to get the bigger sidewall tire. A 275 on a 10in wheel won't have any bulge to it and will look good. There is very little noticeable difference in a 35 sidewall and 40 sidewall.
Darius- My motor is going in basically stock minus MHG and ARP studs, clutch and new OEM crap like WP, timing belt & assembly, gaskets that sort of stuff . Mainly things that is easier to do while the motor is out of the car. It'll make it easier for me to troubleshoot things if the motor is stock. Too bad you live so far away. I'd like to see your setup.
Luke
