17x9 S13 ???
2.240s
Car: 240
s13 hatch if i run fnorc 17x9 20 offset all around 20mm front fenders, 30mm rear fenders.tanabe pro dd coils.i should have no clearence problems right ??also lookin for that stretch look what a good tire size front and rear.??
Modified by 2.240s at 11:30 PM 4/16/2006
McRussellPants
Car: 92 240SX
Running +20 Fronts and +30 Rear Fenders You would need a minimum of a 9 +-0 and 9 -10 to not suck.
17x9 +20 is OEM fender easy stuff.
235/40 is the only tire size for a 9J wheel.
2.240s
Car: 240
so i could get away w/ pulling/rolling fenders front and rear, with 17x9=20 all around?
McRussellPants
Car: 92 240SX
Yes
240sxjeff
Car: nissan 240sx zenki version
Yeah if you put those wider fenders your wheels are gonna look sunken unless you rock some bolt-on spacers.
you could get a 215-45 for a stretched look, 235-40 doesn't look that stretched. I have both and I like the 235 a bit better
