17x9 rotas
jr.
Car: nissans x 7
I have a s13 coupe. Will 17x9 +25 work? if so what size tires should I be looking at?
gumby74
Yes.Depending on how low you can go. Also, I found I needed closer to a +15 offset to clear my front coilovers (Tein) but needed nothing more than a roll on the rear fenders. No pull, and no rubbing anywhere with a 235/40 tire. My wheels are not tucked, I have just about 1.5" of fender gap front and rear and minimal camber (about 1.5* iirc). The rears are actually 17x9 +24 and the fronts are 17x9 +14. I had to use 3mm spacers to get these offsets, but again no issues what so ever. Still have fender liners intact up front and good suspension travel front and rear.
ashibah83
Car: 93 SUPA BLACK COUPE
i went with 17x8.5 +20 d2's check the fitment giude for pics of them....as for tire size i would go no larger than a 235 40 17
