17x9 in the front....
playero_loko
Car: 1991 240sx
i wanted to know mostly if a 17x9 in the with a 20mm spacer would require to much camber that it couldnt be compensated with camber plates??? wheel gods please help!
ashibah83
Car: 93 SUPA BLACK COUPE
what?????
do you mean a 17x9 +20 offset?
if so you need NO camber they fit fine with stock camber measurements
Gabes13
Car: rb20det s13
^tru dat
playero_loko
Car: 1991 240sx
its either (cant remember right now) +12 or +20 offset on a 17x9 with a 5mm spacer in between. would this need too much camber to be to tucked in (just a lil bit)? will it run in the inside? those are the only questions... thankes everyone
ashibah83
a 17x9 +12 with a 5mm spacer (effectively a +7) will require a roll and pull, a 17x9 +20 with a 5mm spacer (+15) will only need a roll, either way they both should fit understock fenders with some modifications, and pretty neutral camber
just FYI, i run -2 degrees on the front on my DD, and as long as your toe is in your tires will last a pretty good while
Modified by ashibah83 at 1:58 PM 4/9/2009
playero_loko
Car: 1991 240sx
So what offset do you think it'd be best to fit with stockish fenders and no spacer?
thanks for the info ashibah.
simmode1
Car: Red '95 S14
playero_loko wrote:So what offset do you think it'd be best to fit with stockish fenders and no spacer?
Anywhere from +20 to +15 is generally a good offset target to get flush with no spacers.
