17x9 and 17x10" Fn01R-c final check...
Fenvy
Car: 2005 350Z Base 6MT
okay, I been doing some research and I want to make sure this is correct.
I have stance gr+ pro coilovers. The car is s13 hatchback
I have a fender roller ready to do the dirty work.
17x9" +15 front with 235/40/1717x0" +12 rear with 255/50/17
does that sound good to you?
eds13
Car: 89 240sx Hatch, 07 Armada LE, 91 Skyline GTR
tires sound kinda monsterly. i would run a 225/40 up front with a 245/40 or a 235/40 out back. but thats me.
alms24sebring
'04 Nissan Sentra SER SpecV
I have the same rims, but mine are 18x8.5,and 9.5 in the rear. (not sure of offset though) the tires on the rear rub the coilover, I was pissed, wheel spacers should do the job. just make sure the rims dont rub the coilover first, then if the tires are to fat to sit under the car, i guess ur ganna have to roll them. if its all good, itll have a nice fffata$$ stance.
gumby74
Are you sure about that 255/50 for the rear? I hope that was a typo.
Fenvy
yes I meant 40
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
Loveless wrote:17x9" +15 front with 235/40/1717x0" +12 rear with 255/50/17. does that sound good to you?
I had the same set-up but I went with 235/45s' the next time I got tires.
When I ran 235/40 up front but the ride quality was sh*t and those reflector things on the highyway when changing lanes sounded like my suspension was being ripped out from underneath the car.
Plus with 235/45 - 255/40 your overall tire diameter and sidewall height front and rear are pretty much as even as they are going to get. However to make that statement more true you would actually need to run a 265/40 out back and then sidewall and tire OD would be damn near perfect but good luck finding that size. They make that size but only 3 tire companies carry it and lowest price was about $160 a tire.
I will take pics of my car tomorrow and show you what 235/45-255/40 looks like.
yokota180sx
Car: 1997 Stagea RS4, r34 front
do it
225/40 235/40
offsets are goo
gumby74
When this gets done, I would love to see a couple of shots of the rear wheels in relation to the fender. I am a little hesitant about that 12 offset. I have a 9.5 at +20 that sticks out a good inch. With a 245 40 and a little neg. camber, and a lip bending, I have just enough clearance. I am still looking at the 17x10 +25 myself. Its easier to go out with a spacer than come back in.
naed240sx
Car: .....
Run a higher offset in the rear. +12 is way too low for an s13 with 255 tires on 10" wheels. That fitment would require 20mm overs.
ddgsxr504
naed240sx wrote:Run a higher offset in the rear. +12 is way too low for an s13 with 255 tires on 10" wheels. That fitment would require 20mm overs.
+25 is the next offset down on 10's for the FN, those tuck nicely on an S14 with just a fender roll so you should be good on an S13.
s14_mike
Car: s14 240sx
I'm planning on running the exact same setup on my s14, i think with a little roll and pull you would be ok with a +12 since you already have the fender roller, and yea to go with the 45 rather than the 40 would make for a better ride. On a side note i noticed that you're from rowland heights and i was wondering where you got your fender roller or if i could rent it off you?
Fenvy
you can rent it off of me
626 261 9414
s14_mike
Car: s14 240sx
cool good deal i'll give u a call im up in oregon right now doing an internship to get them wheels i'll be back in three week so ill give u a call. Thanks again
hsujohn
wow, very cool setup, love it,
Fenvy
okay... so now I have 17x10" +12 rear with 255/50/17 in hand
17x9" +15 front wheels only with no tires
245 is not in the size I want for the brand I want
should I go back down to 235? or go with another manufacturer so I get 245??
Cameron
Car: a 240
and once again i think you meant 50 A.R, but get 235s up front.
Fenvy
ZenkiCam wrote:and once again i think you meant 50 A.R, but get 235s up front.
yes... I meant I have 255/40/17
I paid for 235/40/17 but it's not in stock, I been convinced by phase2 too that the ride quality change is minimal but the height might have some clearance issue if I get 45 instead of 40. Think I should wait some more? The 45s are in stock now. 235/45/17 vs 235/40/17
Cameron
Car: a 240
trust me dude, just wait a lil.. youll be more happy with 40 A.R than 45 since you have coilovers.. you would want 45s had you no coilovers.. just wait for em to be in stock..
2.240s
Car: 240
with the 17x10+12 rears will stick out at least 2in.? ?? ?
gumby74
Yes. You would need a lot of camber and fender work. Do-able, but work none the less.As for the tire size, wait for the 40 series. Or try sourcing them from somewhere else. A 235/45 would be kinda big.
ddgsxr504
Look in my sig, I run this set up and it works fine,
235/45 17 front
255/40 17 rear
stevespeed
Car: RB-Swapped S13, FTW
225/40/17 I have only found in one tire brand of Tire rack and thats a Kuhmo Competition Tire.
