17x9 +35 in the front?
sunnys14
Car: S14
is anyone running FN01r-c 17x9 +35 in the front?? i want to know if that will fit without rubbing on a s14 dropped on sportlines and agx... thanks
chandler
Car: 91 civic hb & 96 S14
I would like to know also, will it fit flush?
BaliLover
I'm very doubtful they'll fit. 17x9 +20 barely clears on mine with coilovers, you're over a 1/2" further to the inside
chmercer
doubt it will fit. and it wont be flush
chandler
well, chmercer, since you have so many beautiful wheels, what sizes would you reccomend on my 96 s14 se, that would look flush with the body with a little bit of sunken hub/spokes?
chmercer
the only type of fns that come with the dished spoke design are the 10" wide ones. easy, decent fitment wheels would be 17x9 +15 17x10 +25. i would suggest this fitment if you want to run largish tires, say, 235 front 255 rear or so with a little room for extra. this would require rolling the fenders but no pull, so it wouldnt change the exterior appearance at all. if i was going to put 17" FNs on a stock bodied s14, personally, i would put 17x9 +15 in the front with about 10mm worth of spacer, and in the rear would be 17x10 +12 with a 8 mil plate or so. but that might be a little more fender rolling / pulling than most people seem to be willing to do.
if you want to run 17x10 all around to get the sunken spoke look, that is possible to do as well, without buying any extra parts, but it would take a little bit of work to do.
chandler
thanks man, I appreciate it
sunnys14
Car: S14
so no 17x9 + 25 in the front then huh? i have a 17x10 +35 in the rear so i dont want anything to stick out in the front than in the rear...
