sil80drifter »
https://forums.nicoclub.com/sil80drifter-u622.html
Mon Dec 12, 2005 5:23 pm
I am always confused when people say "won't clear coilovers"does this mean it would clear regular stock spring/shock combo? or it won't clear the inside at all because it's too close to the strut assembly?confusing because the coilovers on 240s are usually skinnier (diameter wise) than the regular spring/shock comobs, so they should clear wider wheels.... right?
OH! just got a great hint from someone, the shocks/springs ARE wider, but they are above the wheel, because the bottom of the strut housing is higher than the tire. So the coilovers ARE skinnier as such, but they are sitting right next to the tire.
This person also told me (and I've seen it, just didn't know) that he ran a 17x8 with a 38 mm offfset. this means that hee has SEVENTEEN(17!!) mm less clearance on the inside, compared to my proposed offset of 26 which is 18mm, only 1mm more, BUT I am running shocks/springs not coilvers, like he did.So it SHOULD work. Without coilovers, like you said McRusselPants. but for those I could just get a small spacer. Of course I'd have to roll and stretch the crap out of my fenders... Well worth it I'll update you guys when I try this.
Also thanks for the links, but they all mention different offsets from what I plan on, people saying that 17x9 with a 15 and 20 offset will clear but nothing about 26.... I was starting to think about the 17x8, but that would kill my plans.... I really like the cobra replicas witht heir 17x9....I'm still re-searching as well, but I could always use some more hints.
sil80
Modified by sil80drifter at 10:35 PM 12/12/2005
