17x9 +20 on S13??
crazyfast
Car: carz carz carz
well... as topic.. will 17x9 +20 offset fit the rear and 17x8 +35 for the front? do I need any spacer or any extra mod?I have KYB shocks!!plz help, buying rims in 2 days
and which size I buy to look like the one in pic?
deCksy
the 17x9 +20 should look pretty damn good on the rear (you'll probably need to roll them fenders), but the 17x8 +35 would need some spacers, id say a 15mm or 20mm
BaliLover
I run 17x9 +20 in the rear of my S13 with a 235/40 tire. I'm lowered with megan racing coilovers set at the height they were at when I removed the from the box. The camber is at whatever the coilovers put it at. They clear everything, I didn't even have to roll the inner lip, but if I ever want to remove some of that camber, I'll need a roll done so I don't eat the edge of my tire.
ibzbro
Car: paintball, and cars
in that pic the fronts are 17x10 +12
ca18detizzle
yup.. nikolay is pretty hardcore! shooot....
GhostDriver
Car: 1991 Nissan 240SX RMS13
Strechmo satchmo.
veilside180sx
Nikolay is running the 17x10's. The face on the rim is different between the 10" wide and the 9" wide.
ca18detizzle
wonder what size tires are the 17x10's.
chmercer
looks like a 225
crazyfast
Car: carz carz carz
So what size of tires do you guys recommend for 17x8 for the front and 17x9 for the rear?I use KYB shocks!
mynismo
im really really considering 17x9 +20 235/40/17 all around............... one question
will they clear d2 coilovers in the front? if not who sells the +15 in 4 lug?
808DRFTR
Car: 89 240sx KA24DE Swap
91 240sx SR20DET Swap
02 Sentra SER Spec V
01 QX4 4x4 Lifted
01 I30
11 M56 Sport
no +15 in 4 lug, theres only 17x7 +35, 17x8 +35, & 17x9 +20 for s13's
sixxdeuce
Car: 93 rx7, G35coupe 6mt
17x9+15 4 lug is available in the Grenade gx-01. They are a pretty heavy wheel tho, a little more than the fn's. They run $220 each. Oh, and 17x8+35 will look like ****, go 17x9+20 all 4.
veilside180sx
the 17x9 +20 should clear the D2's pretty easily, as I have the 17x8 +35 and they barely clear my D2's.
You finicky wheel snobs. 17x8 +35 does not look bad, it doesn't have to be uber flush to be nice. It also does not have to be sticking out of the fender to be nice.
sixxdeuce
I have also owned a set of 17x8+35 wheels, that uber sunk look just isnt my thing I guess.
raging panda
Car: s13 coupe
yeah, i hate the sunken look. Grenades are going to go up in price soon. the 220 is only for this month. I would love grenades but they wanted 25 per wheel shipping which just put them out of my range. im running 215/45/17 on my 17X9 +20. i must say that im pretty close with 215, im not sure if you will have any clearance isues with 235, but you're going to have to roll fenders anyways, it just might need a little pull added to it.
onosqv
Car: '92 240sx Vert
mynismo wrote:im really really considering 17x9 +20 235/40/17 all around............... one question
+10mm spacer, haha. Or you can get grenade wheels in +15.
mynismo
thanks guys. already rolled fenders for current bulged 16x7+32 245's on the back, that aint a problem.
i called spl to order the fn01rc's but they are all sold out for another three months. i guess ill just wait until then. the gernades are too heavy at 25lbs. 5zigen's are only 20 lbs.
thanks, im going 17x9+20 all around, the only thing i was concerned about was clearance of front coilovers but i've seen quite a few people running them so that shouldn't be a problem. 235/40/17 will go all around.
thanks! mark these seem like near perfect offset and look for 4lug'd s13's. i was going to go 5 lug and fit 10's on the rear but then the fronts aren't concaved and the rears are... it doesn't look right.
