17x9 + 17
boriquaS13
Car: 92 240sx
What do you guess think of running 17x9 + 17 offset on all four corners?And also what tire size suggestions and what are the performance benifits of running the same size all the way around?
nismofly
Car: 89 Nissan 240SX Hatch
s13? good stuff
run 235/40/17 all around...car wont understeer like crazy is the biggest benefit
Logan76
Car: Junk
Well, the benefits of going the same size all around is you can rotate your tires for longer life, and it wont cost you as much in the long run, that isnt too bad of an offset for a 240, with a little bit of camber and a roll/pull you should fit those quite well.
boriquaS13
Car: 92 240sx
Yeah its an s13, Im also going to run stance coilovers any forseable problems with clearance, I was told that with a slight roll in the rear with negative camber would clear and just negative camber for the front would clear with no problems. Btw the wheels are a tech weapons buying them from enjuku racing. I also am installing polyurethain bushings in the suspeinsion. When I learn how to post pictures I will.
nzmoman
Car: 240sx 2 of em' and always lookin for more
get your pics put them on photobucket for hosting.
either copy them from the [IMG] tag on photobucket and paste them to your post or post a link to your photobucket album.
I want to see what you are doing pretty bad cause im getting ready to do my first wheel upgrade.
nismofly
itll need a roll and a small pull, depending on how much camber you want to run, both ends
boriquaS13
Car: 92 240sx
How much negative camber would i need to run to make it happen, I have been told that i would have to do a slight roll but not a pull if i run enough negative camber by enjuku. What do you suggest?
boriquaS13
Car: 92 240sx
Ordering the wheels monday so when I receive them I'll see if I can at least post some pic's of the wheel. Still waiting on the 5 lug conversion I also ordered them from enjuku and they said they would get them on the 20th if feb . Anyhow the front bushing install is done starting on the rear I'm thinking of pulling the hole rear subframe with everyhting on it because its looks easier to do that way. I'll keep you posted and upto date. Peace out.
94_240sx
Car: 94_240SX
boriquaS13 wrote:Im also going to run stance coilovers any forseable problems with clearance, I was told that with a slight roll in the rear with negative camber would clear and just negative camber for the front would clear with no problems.
You will have no clearance issue w/Stance. 235 on 9 will have slight stretched look, but not much. You just install everything including RUCA in the rear and have to kinda play around with height and stuff. Take your time and adjust here and there to figure out what need to be done. You will have a fun for a while doing it.
boriquaS13
Car: 92 240sx
My 240 sx!!!!!
koukicody
Car: 93 Mazda Miata
im guessing your getting the MB Weapons?
boriquaS13
Car: 92 240sx
my front polyurethane install up frontSexy wheels that came with the carz32 front rotors heheheR+R'd rear subframe for rear bushing install also going to install ruca's yeah baby!!!!
boriquaS13
Car: 92 240sx
Nope just checked A-tech weapons.
Lil_JV
Car: 1991 180SX
hannibal
Car: Red Line to Glenmont
boriquaS13 wrote:Nope just checked A-tech weapons.
Same as MB Motorsports Weapons, just different name... MB's are sold 'exclusively' by DiscountTire.com. The Weapons are $140 apiece.
boriquaS13
Car: 92 240sx
Lil_JV wrote:235/40/17
Yep 235-40-17 Havn't decided on brand yet though.
IWannaS15 wrote:Same as MB Motorsports Weapons, just different name... MB's are sold 'exclusively' by DiscountTire.com. The Weapons are $140 apiece.
I'm such a dummy, and yep your right to.
I'm o for 2....... damn it
boriquaS13
Car: 92 240sx
Oh yeah I did get to order the wheels (17x9 + 17on all 4 corners baby!) but they said 1 1/2 weeks to get them . And still no stance coilovers what the hell are they on national backorder . Any ways I'll keep calling till they come in.
